Got my car back from the garage after servicing the Aircondition.
Changed Radiator and tubes, and topped up new fluid.
The Aircon worked for 1 hour and then stopped cooling.
The Garage has shut down for summer holliday; 4 weeks.
Where shall I start looking to get the Airconditioner fixed and working again.
The fuses are ok, but the relay were hot !?
Any suggestions very appreciated.
Aircondition Thema SW V6 1993
Mike
Re: Aircondition Thema SW V6 1993
The aircon unit has a self diagnostic function that can be run by pressing the "AUTO" and "VENT" buttons at the same time. The System will then go through a test cycle which tries out all the fan speeds, vents etc.
It takes about 20 seconds, during which time the display will flash. Once the testing is complete the system will display a number to indicate the number of vaults detected. Press "VENT" and you will be shown a 2 digit code for each of the faults found.
If you can find a Lancia dealer they should be able to give you a list of which faults relate to which codes. I should have a copy of this somewhere and will try to find it for you.
I would, however, guess that the temperature sensor may be broken, but that is just a guess.
If you search on air conditioning you may see a previous question that I raised on this subject which was answered more fully.
Mike
Look for a message titled "A/C fan not blowing" dated 6/11/02.
In this thread of messages you will find a message from Paul O which list the faults codes.
Good Luck!
Good Luck!
Stoljak
Tried the selfdiagnostic but that answered Zero problems !
Could it be that there are more leaks and the fluid level is sero again.
How do I check fluid level ?
Nils
Nils
