Urgent help needed, stuck in Netherlands / Dringend hulp nodig, vast te zitten in Nederland
lanciathema.nl
Re: Urgent help needed, stuck in Netherlands / Dringend hulp nodig, vast te zitten in Nederland
It's a known problem. Not major in most cases. It's probably the sensor in the exhaust which is polluted. Also your EGR valve might need cleening.
thesisfan11
Had the same issue recently and as Lanciathema.nl said: clean the erg and sensor!
Should help you out very quickly.
Then for the future: add 40ml of 2-stroke full synthetic oil to each full re-fill.
This helps for better fuel burning as nowadays Diesel/Gazole is very low on additives.
Good luck.
Jos
Good luck.
Jos
