Hi folks,
Can somebody please advise me on the correct sequence for re-fitting a rear side window on my S1 Zagato. I removed it to have some minor repairs made where the paint has blistered but would like to know the correct sequence to re-install it. Is the chrome strip around the window fitted before the window is fitted into the body or is it fitted afterwards? I was not too concerned when removing it because the rubber was damaged and needs to be replaced but I don't want to damage the new rubber when putting it back.
Bryan
Advice on fitting S1 zagato side window
Re: Advice on fitting S1 zagato side window
the chrome strip around the window have fitted before you put the window into the body. Otherwise you don´t have a chance.
There is a recess inside of the seal to keep the chrome strip later in position.
In general a difficult job. You have to have patience to do that and good nerves.
good luck
Regards Andreas
good luck
Regards Andreas
Many thanks Andreas. Do you fit it the old fashioned way (soap and a piece of string) or are there more scientific ways these days ?
regards
Bryan
regards
Bryan
Bryan
PS.:
old fashion needs old fashion
-D
PS.:
lancialulu
And an extra pair of strong hands ..... String broke a couple of times. Think I changed to nylon strimmer string.
Not a job I want to do ever again.
Tim
Tim
Thanks Tim, you fill me with confidence especially as a new rubber is not cheap !
Bryan
Bryan
Bryan
Just to finally report that after a long wait for the rubber to arrive from Italy (on foot?) I was able to fit the window. In fact it went in easily with a good dose of soap, some strong string and my son pushing from the ouside. Thanks to all for the good advise.
Bryan
Bryan
Bryan
