Air Debitmeter
Mishu
Air Debitmeter
Post by Mishu »
I own a Thema i.e 8V from 1987.
I need help cause my debitmeter is not functioning well and needs to be repleced. The problem is that the only one I could find was TOO EXPENSIV. Around 900$.
I need to know if any other car manufacturer uses the sane tipe of debitmeter. The code is 0280202059.
That way I can find one at a scrap yard.
Thanks a lot.
About the car.
I SIMPLY LOVE IT.
oystein r
Re: Air Debitmeter
Post by oystein r »
Fiat Croma 2.0 ie (non-turbo) uses the same one
MIshu
Re: Air Debitmeter
Post by MIshu »
Apparently I can't find any of them.
I there any other model that I can use?
I found the following 0280202202, 0280202031. And few others I can't remember there codes.
oystein r
Re: Air Debitmeter
Post by oystein r »
Not that i know of. Maybe alfa 164 2.0t has the same. check out your local scrapyards. Take a trip to Oslo, Norway, and I'll point you to one
Pol
Re: Air Debitmeter
Post by Pol »
Hi Mishu,
I checked the Bosch online-catalog for the vehicles matching the numbers you gave:
0280202059 :
FIAT - CROMA (154) - 2000 i.e. (154.AD)
03.87-09.92 (year fitted)
LANCI - THEMA (834) - 2000 i.e (834AB)
09.88-05.92
LANCI - THEMA (834) - 2000 i.e. (834B)
11.84-09.88
0280202202 :
Alfa 75 , 155 , 164
Citroën BX , ZX
0280202031:
BMW 320 , 323 , 520
Conclusion : the one fitted in your car was only used in Thema & Croma 8V's non-turbo, looking for it in any other car could be a waste of time.
Where do you live? I know a good scrapyard in Belgium ....
Pol
MIshu
Re: Air Debitmeter
Post by MIshu »
Thanks a lot!
That's exactely what I was afraid off.
About the scrapyard in Belgium. I live in Romania so that not a solution. But thanks anyway.
Return to “51 Thema”
