Ich habe mein Thesis umgerüstet mit electrischen Sitze mit Heizung (und andere emblema optionen). Das meiste functioniert, ausser is die warn Leuchte/Symbol des Heizung. Könte ich was vergessen sein mit die umrustung oder hat das zu tun mit der programmierung des NIT? Was ist die location des Symbol, am Connect Display oder auf das Display im Armaturenbrett?
Ich hoffe ihr könnte mir weiter helfen!
Gruss
warnleuchte sitzheizung
Re: warnleuchte sitzheizung
If you mean the heater in the setup in connect it's an option for the webasto. Seat comfort is available only with comfort massage front seats installed. If you have normal seats with heating than it should be operated via a knob on the seat side. It's controlled via the ecu under the driver's seat (if I remember that correctly that there's none under the passengers one). Comfort seats have two ecus, drivers and passengers.
Lancia Thesis 3,2 V6 + LPG Emblema 2007
Lancia Thesis 3,0 V6 Emblema 2004
Lancia K coupe 20VT 1998
Lancia K coupe 20VT 1999
Alfa Romeo Spider 3.0 V6 12V Lusso 2000
ICQ: 312857200
e-mail: vladimir.duro@lanciathesis.eu
Phone: 00421-907/087956
www.facebook.com/lanciathesiseu
www.vialleslovakia.sk
If you have any problems with your thesis, feel free to contact me.
ICQ: 312857200
Hi Vladimir,
I mean the normal seat. The heating works perfect with the switch on the seat side. Just it would be nice to have the warning light/symbol on the dashboard working as well. I remember some time ago you indicated it is needed to update the connect system to "emblema" to have all functionality available. Could that be the reason? I have an executive, but I have build in the seats, bose system, steering wheel etc. from a donor Emblema car.
Do you know if the seat heater indication is at the center screen or at the one behind the steering wheel?
Anyway thanks for the advice!
Hi, if I understand that correctly you are mentioning some indication symbol that says you that the heater is on? Unfortunately there's nothing like that, no symbol in each thesis. Even emblema doesn't have such a feature.
ICQ: 312857200
ICQ: 312857200
Ah, you saved me a lot of additional researching, thanks!
It is described in the elearn workshopmanual, and i believe also in the ownersmanual, but for sure it is not the first time there is a mismatch between those and the actual cars.
Can you please upload that page from the owners manual or say the page number and the manual rev. number so I can check it what you exactly mean.
ICQ: 312857200
ICQ: 312857200
In Elearn it is mentioned in section E3075, Heated Seats Discription.
For the owners manual (I have the Dutch version, so exact page could differ), it's on page 62, Front seats, near figure 42.
Finally found it in elearn. This info there is not correct. There's no message. Never.
ICQ: 312857200
ICQ: 312857200
Thanks for looking into it! Then my conversion project Executive --> Emblema is about ready
Hallo Frezer,
die einzige Info über eine eingeschaltete Sitzheizung bekommst du in der Übersicht im Setup Menu des Connect.
Also wenn du die Zündung anmachst und die Heizung anschaltest, dann auf Setup drückst und dann unten links auf Übersicht gehst.
Dann siehst du eine "luftaufnahme" von einem Lancia Lybra (sollte wohl eigentlich ein Thesis werden) und es werden nach und nach rot leuchtende Symbole für die eingeschalteten Funktionen angezeigt. Wie Türverriegelung, Handbremse, Sitzheiung, ...
Die Infos dazu stehen wahrscheinlich dann im Connect Handbuch.
Viele Grüße, Ivo
Viva-Lancia!
Viva-Lancia!
