Intermittent dont light (of course it is not the bulb)
kassus
Unread post by kassus »
hi,
the left small intermittent ( near the door ) dont works in any mode ( four, left side, alarm off, alarm on) and it is not the bulb, anyone knows anything about it, another electrical problem...
pd: the cables are black and blue, but i loose them in the way, i dont know where they go
paul.o
Re: Intermittent dont light (of course it is not the bulb)
Unread post by paul.o »
If you mean the side indicator bulb ,the one on the front wings, then the wiring goes to the same front indictor connector. In most cases the bulb connector metal work is rusted or the earth connection is rusted which are below the front indicators. You can see the the earth connection better if you get under the car.
Return to “51 Thema”
