hello
when the engine and conctact are off, my windows (front left) works and i can use it, so the right doesnt. the same happends when i close the car with the distance command: left close automatcly so rihgt do no, why?
						front electrical windows
				David Hanson
Re: front electrical windows
Unread post by David Hanson »
All themas I've seen allow the Drivers window to work with the key off but only if the door is open. My guess is that the switch that tells the car the door is open is broken and therefore always allows the window to work.
				kassus
Unread post by kassus »
Thats correct, so only in my window (front left)?
A friend as a Croma and also works in the front right window
thanks
