Hallo Thesistis,
ich habe mal eine Frage zur Fehlermeldung "Defekt Klemmschutz Fenster Hi".
Fenster geht mit mehrmaliger Betätigung noch zu. Kann man die Meldung aus den Fehlerspeicher löschen? Oder ist wirklich was defekt.
Re: Defekt Klemmschutz Fenster Hi
If I understand that correctly your problem is the antitrap system and I believe it's on the rear window, is that correct?
Lancia Thesis 3,2 V6 + LPG Emblema 2007
Lancia Thesis 3,0 V6 Emblema 2004
Lancia K coupe 20VT 1998
Lancia K coupe 20VT 1999
Alfa Romeo Spider 3.0 V6 12V Lusso 2000
ICQ: 312857200
e-mail: vladimir.duro@lanciathesis.eu
Phone: 00421-907/087956
www.facebook.com/lanciathesiseu
www.vialleslovakia.sk
If you have any problems with your thesis, feel free to contact me.
ICQ: 312857200
hello vlad 47,
yes, exactly behind left pane, Do you know any advice?
I had this problem on both thesises and didn't know what causes it for a very long time and than I've found it. You know that this problem is caused by loosing a connection of the antitrap sensor, but the problem is not in the door. Front door has each it's own control unit, but the rear doors use the central one which is also for the tailgate etc. It's located it the trunk on the left side. Antitrap connection lost is caused by moving a connector from the door in it. Moving is caused by a cable that is going from the tailgate because when you open them the cable is pushing the connector. Try to find a position when it's working and then fix it and prevent it from moving while opening the tailgate. In a good position the dashboard doesn't splash the error and after calibrating the window rises at once.
ICQ: 312857200
ICQ: 312857200
thanks allot
I'll give it a try, you then let you know. Greetings from Berlin
