Hello,
I wonder if there is someone who has got the wiring diagram to the rear electric windows for a 16V Thema S2. The electric windows don't work and I was planning to fix them before summer.
Greetings
Stefan Petrovic
						Wiring diagram?
				David Hanson
Re: Wiring diagram?
The problem is most likely the switches - it is possible to pull the switches apart and clean the contacts. Both my Themas have had problems with these switches, cleaning them has worked every time.
				Stefan
Re: Wiring diagram?
But, I have problems with both rear electric windows which can be controlled from four switchers(one switcher at every door plus two switchers between the front seats). It sounds to me that there is something wrong before those switchers or am I wrong?
				David Hanson
Re: Wiring diagram?
On one of my themas ALL the four switches required cleaning. It still could be possible however that you have a blown fuse except I think that there is only one fuse for all the windows.
				paul.o
Re: Wiring diagram?
If the fuses for the rear windows are ok then check the switch that stops the rear windows from working. Its the square button in front of the window switches between the front seats. This switch unlike other cars also stops all four  windows switches from working not just the rear ones. The connector that fits to it may have fell off or it may be broken. If the switch is ok then the switch contols a relay which you can here clicking when pressed, this relay is mounted behind the ash tray and could be faulty. The above applies to a series 2 thema but should be the same for a S3
