Alfa OBD2
Mücke
Alfa OBD2
Unread post by Mücke »
Hat schon einer von euch mit den Alfa Obd2 die Parkbremse angesteuert??Also geöffnet und geschlossen?
vlad47
Re: Alfa OBD2
Unread post by vlad47 »
Yes it's supported in alfaobd, also the closing, opening, calibration etc. But the connection is not via can, it's directly via pin. I can't remember the number, can have a look at it if you like. You have to repin it to the pin number 7 to get connected on it. The parking brake is on the backnode.
Lancia Thesis 3,2 V6 + LPG Emblema 2007
Lancia Thesis 3,0 V6 Emblema 2004
Lancia K coupe 20VT 1998
Lancia K coupe 20VT 1999
Alfa Romeo Spider 3.0 V6 12V Lusso 2000
ICQ: 312857200
e-mail: vladimir.duro@lanciathesis.eu
Phone: 00421-907/087956
www.facebook.com/lanciathesiseu
www.vialleslovakia.sk
If you have any problems with your thesis, feel free to contact me.
Mücke
Re: Alfa OBD2
Hello Vladimir,
I do not understand what you want me to say?
So I can not use the OBD2 plug easily open and close for the installation of new brake pads?
I have seen a tool looks like an OBD hand-held computer from TRW with you possibly can drive EPB, abe costs a lot ...
vlad47
Re: Alfa OBD2
What I want to say that it's possible but you have to make a modification to your adapter.
ICQ: 312857200
Mücke
Re: Alfa OBD2
Dann Verrate es mir Vladimir!!!!!!:)
vlad47
Re: Alfa OBD2
I'm not trying to hide it, but I can't remember which pin is for the rear node. You know there are more pins, each for something else :). But I've ordered another adapter as I've lost mine somewhere so will be modifying it this week. Oh yes, than I can add also some photos :)
ICQ: 312857200
Mücke
Re: Alfa OBD2
ok dann warte ich mal....(tu)
tiefimwesten
Re: Alfa OBD2
Unread post by tiefimwesten »
Ist es so kompliziert wie es sich anhört?
Kann man nicht einfach über das Connect die EPB mit dem "Häckchen"
geöffnet lassen, die Beläge / Bremsscheiben wechseln und dann hat es sich???
Bitte laßt mich einen Gedankenfehler meinerseits wissen. Uli
aragorn2006
Re: Alfa OBD2
Unread post by aragorn2006 »
Soweit ich weis nicht, weil Du die EPB ganz auffahren muss und dann wird es auch damit kalibriert.
Allzeit gute Fahrt
Aragorn
Lancia Thesis 3.0 215 PS Bj.2002 89000 km
Lancia Kappa 2.0 155 PS
Fiat Marea 2,4 JTD
Piaggio X9 500
Mücke
Re: Alfa OBD2
Genau so ist es(tu)!tt!
Die EPB läuft immer mit den Aktuellen Verschleiß der Klötze mit,deshalb wirst du wenn du das Häckchen im Connect machst nur die Jetzt Stellung der Klötze haben nicht die Null Stellung der EPB.Du kannst die Alte Klötze Rausholen, aber die neuen mit der Vollen Stärke nicht einbauen weil du sie nicht auf die Scheibe gedrückt bekommst.Bin am Überlegen mir bei TRW so ein EPB Rücksteller zu kaufen,kostet aber nen paar Euro,muss mir das mit meinen Bruder halt teilen hehehehe der wird Sie nämlich eher brauchen als Ich!
Return to “D30 Thesis”
