Rear fog light fuse location ?
Pierre VALLADE
Unread post by Pierre VALLADE »
Hi all Thesis specialists,
I am facing an issue regarding the rear fog light - left side. There are no voltage. Of course I have always an error message at the dashboard.
The right size is OK.
I suspect the fuse ... but reading the user manuel, I can find a lot of fuses but nothing related to the rear fog light.
Does anyone knows where it is located ?
Is there a fuse for each side or only one for both ?
Any help from some one who got the same issue ?
Help appreciate ... english or french prefered.
Many thanks.
Pierre
Aurelia B21, Flaminia GTL, Flavia Milleotto, 2000 coupé,
Beta HPE, Beta Trevi VX, Prisma 1.6, Kappa coupés 2.4 & T20, Thesis V6 3.0
Robbedoes
Re: Rear fog light fuse location ?
Unread post by Robbedoes »
I have the same error, didn't knew it was the fog-light.....
karel
Unread post by karel »
be prepared for possible wiring trouble.
Broken wire is more common than blown fuse. Wires of boot lid tend to succumb to metal fatigue at the point where the pass through te hinge.
It is necessary to address the issue not just for the fog light, but sooner or later the electrical boot lock will fail as well
Return to “NL35 Thesis”
