Sluggish feel
Leon
Sluggish feel
Unread post by Leon »
Hi,
Got my '91 Lancia a couple of months back. Gave it a new coat of
paint, fixed the speedo, tightened some of the loose plastics
in the cabin, replaced some injection ring part when she died
on me as I was coming out of the highway. Made a hole in wallet. :(
Now she looks good, runs fine 'cept for a couple of problems (well,
not really serious ones, I hope):
a. strong exhaust smell in the cabin when air-con is not running
at full blast or when she's idling (smell is more obvious to back
seat passengers)
b. sluggish feeling when accelerator is depressed immediately
after letting go completely when travelling at high speed (above
100km/h)
c. warning sensor for brake lights come on occasionally and go
off after 1 or 2 seconds when car is going at high speed
d. high idle speed (between 1,000 to 1,500 rpm) that fluctuates
between stops - sometimes goes up to 1,500 rpm, at other times
drops to 1,000 especially when air-con compressor activates
Appreciate any advice on these problems. Thanks in advance!
Best wishes,
Leon
Hugo Pinto
Re: Sluggish feel
Unread post by Hugo Pinto »
Hi Leon
>seat passengers)
I believe i read somewhere (probably in this forum) that this problem comes with almost all dedras!!
When it was beeing sold they returned to factory so they could fix it, but many still out there!!!
I have the same problem..... But going to check where's the problem, i believe its in a falty joint....
>100km/h)
and
No big ideas here... Air filter damaged or old or air intake with obstructions..???
Last weekend i found the same problem in my dedra... When the rain comes.... the lights flash!!!
Good isolation will help prevent this problem, verify the rubers in your stop lights case....
Hope my experiences help you solve the problem....
Best Regards
Hugo Pinto
Leon
Re: Sluggish feel
Hi Hugo,
Thanks for your reply. :)
> comes with almost all dedras!! When it was beeing sold they returned
> to factory so they could fix it, but many still out there!!! I have the same
> falty joint....
I did a search on the net sometime back and came across an
article that mentioned a factory recall for Dedras manufactured
around 90-91. There was mention of a missing seal between
the back and side panel (or something to that effect) and that
was resulting in the exhaust penetrating the cabin. Strangely,
I can't seem to find that article online anymore. If only I knew the
exact position of the hole, then I could plug it myself somehow...
Tried changing the air filter. There wasn't any significant improvement
where these problems were concerned. I have considered that It
could be a leaky air filter housing as the area around the large
screw holding down the air filter housing has cracked before and
was patched using strong glue.
I do notice that the sluggishness does not appear when I top up my
petrol tank to full. I'm not sure if the topping up of the tank affects the
problem directly or if it's just psychology at work.
A friend has suggested that I change the water sensor. Although I
have the Lancia Dedra owner's manual (two of them in fact - one in
brand new condition!), it doesn't state the location of the water
sensor. Also, I'm quite limited where parts are concerned because
I'm located in the Far East (Singapore) and the local distributor of
Fiat and Lancia parts doesn't stock much (there are only 80+
Lancias in Singapore!). I have tried searching for online sources of
Lancia parts but have not come across any that would take payment
online and ship over to my place.
> rain comes.... the lights flash!!! Good isolation will help prevent this
I see... in my case however, it happens sporadically whether or not
it is raining. Seems to me that the car's electronic brain might be
getting a little senile... :)
Thanks, really appreciate the information that you have given me.
Enjoy your Dedra(s)!
Best wishes,
Leon
Chris
Re: Sluggish feel
Unread post by Chris »
Exhaust smell.
There was a dealer call back for all Dedras. At the side where the exhaust pipe is at rear of car they simply sealed a vent which was under the bumper. I did have the recall sheet at that time approx.1994/5 and also reissues as per LMC approx2000/1.
Regards Chris.
Leon wrote:
> Hi Hugo,
> running
> this problem
> returned
> believe its in a
> > falty joint....
> manufactured
> knew the
> somehow...
> immediately
> fluctuates
> improvement
> large
> and
> up my
> tank affects the
> Although I
> one in
> water
> because
> distributor of
> sources of
> payment
> go
> prevent this
> or not
> might be
> me.
> Best wishes,
> Leon
Leon
Re: Sluggish feel
Hi Chris,
> Exhaust smell.
> approx2000/1.
Thanks for the info!
Best wishes,
Leon
Kim Thomas
Re: Sluggish feel
Unread post by Kim Thomas »
I f your still looking for the temp sensor its on the inlet manifold and has two wires coming out of it with a blue socket.
My dedra also has a fluctuating throtle and various problems, my car is known to have a dodgy fuel pump which works much better when fuel tank is full! So might be worth looking at.
Leon
Re: Sluggish feel
Hi Kim,
Thanks for the information.
For the fluctuating throttle, I got my mechanic to adjust the engine
timing and it helped. The RPM is around 900 to 950 and does not
fluctuate much now.
Also, just my observation, not sure if you experience this, pressing
the accelerator excessively seems to "flood" the combustion
chamber resulting in a sluggish feel when the next gear is activated.
Best wishes,
Leon
Simon
Re: Sluggish feel
Unread post by Simon »
Leon,
I had a 1.8 and had the problem where the engine would appear to appear to stutter every how and then just as the thermostat was about to open, The garage i used rolling road tuned it but could not find a problem. However they had heard of a similar problem where the car stalled and attributed it to the temperature sender. They replaced mine and never had the problem again. The part also fits a Ford Escort RS.
Simon
England
Leon
Re: Sluggish feel
Hi Simon,
Thanks, I guess the next item on my to-change list will be the
temperature sensor. Just need to find some way of importing
it in.
Best wishes,
Leon
Ove-Andre
Re: Sluggish feel
Unread post by Ove-Andre »
About the abnormal rpm at idle.
Check if the EGR system is working correctly.
It might be letting exhaust into the inlet-manifold at idle,
resulting in poor stability.
You really don't need it, you can disconnect the vacuumhose to check.
oa
Return to “55 Dedra”
