Hi,
I Have a Dedra 1.6.i.e equiped with ar-condicioner. When i turn it on and press the external temperature button, it shows "-29". I think that's a problem with the externel temperature sensor but i don't know where it is. Anyone knows?
Thanks in advance
Temperature sensor
Duarte
Re: Temperature sensor
Are you sure? I have opened both mirrors and all i could find was the mirrors and the heat resistors...is there another possible place for that sensor ?
goofy
you have to take whole left mirror from the door. sensor is in the plate which connects the mirror to the door.follow the wiring if its still hard to find.
Duarte
Hi Goofy,
I have found the temperature sensor where you told me it would be. The malfunction has been repared and it's working fine. Nothing was wrong with it, but as i follow the wiring from the sensor, i found a "scart" (is this correct english?) disconnected near the fuse box...lol...
Well, it's working and THANK YOU VERY MUCH for your help
Cya
Cya
