1996 New Delta Speedo
Gustavo Melo
Post by Gustavo Melo »
Hi,
I have a problem with my 96 Delta; both the speedo and the tachometer doesn't return to zero; the speedo stops at 20Km/h and the tacho at 500rpm, and the strangest part is that the odometer, when the ignition is turned on, and the car stopped, counts!
Is this a common problem with an easy solution?
TIA,
Gustavo Melo
Guy Fawkes
Re: 1996 New Delta Speedo
Post by Guy Fawkes »
Sounds like an earthing problem - try cleaning the earths.
Dave Crook
Post by Dave Crook »
The speedo's sit at 20kph!! if u look closely there should be a black pin that the needle sits on!! not sure bout the rest though sorry
Return to “57 Delta, Prisma, Delta Integrale”
