Parksensorfehler nicht gefunden. Neuen Fehler erzeugt und repariert.
Moses
Re: [ Erledigt ] Re: Parksensorfehler nicht gefunden.
Unread post by Moses »
Yes Vidar, the buzzer is inside the luggage space under the cover. You have to remove the cover, after it´s finished there are some "holes" in the metal plate. Inside one hole on the left side you can feel the buzzer and can see some cables.
The buzzers ist fixed by two srews, in my case it was not possible to remove the screws. I bought a new buzzer and fixed it with double tape on the metal plate. That´s it.
Regards
Moses
vidarsta
Unread post by vidarsta »
Thank You very much !
I will look into this tomorrow.
Regards
Vidar
Return to “D30 Thesis”
