Auteur: Marc Rijnders (---.abz.nl)
Datum: 17-09-01 08:50
After years of fine using the horn it decided last week to stop. Not knowing if it is the actual horn or the wiring, I have the following question. Who can tell me the location of the horn. I have been looking this weekend but with all the rain lately it is no pleasure to be outside. The fuses and relais are working properly so the problem much be further down the wiring. Who can help me to find the noise back?
Thank you very much in advance.
Yours sincerelly,
Marc Rijnders
2x Delta HF Turbo 1989
1x Ypsillon Turbo 1986
Horn with Delta HF Turbo 1989
Steve Matthews
Re: Horn with Delta HF Turbo 1989
On my 1987 Delta GTie the horn is mounted under the front bumper infrot of the wheel arch on the air box side of the car.
Mine had twin magneto horns on it so I would suggest it could be a wiring problem as it would be odd for both to stop working together.
Good luck,
Steve Matthews
www.pentagram-motorsport.com
Good luck,
Steve Matthews
Marc Rijnders
Steve,
Thank you so much. I will go and check it asap.
Maybe you have some tips for me with removing the front-bumper.
Thanks.
Regards,
Marc
Thanks.
Regards,
Marc
JFP
Normally, no need to remove the bumper. On my 89 8v, the horns where totally destroyed by the heat of the turbo which is very near.... Otherwise, bumper bolts are behind the Fog beams
