lancia beta gearbox separtion
Posted: 02 Nov 2006, 01:14
by keegan
hello all, i am in the middle of making 2 lancia beta's into 1. I have taken the subframe out of the car and have taken the engine of the mounts so i can repaint and rubush the subframe. Right now i am trying to separate the gearbox from the engine so i can move them around a bit easier. The manual says all i had to do was undo the main bolts around the housing and the nut near the drive shaft at the rear. I have got the two to separate about 5cm but beyond that is proving very diffucult. Is there anything i am missing or should look out for ? thank you
Re: lancia beta gearbox separtion
Posted: 02 Nov 2006, 13:08
by william vd Sman
You've probably forgotten to remove the moonshaped sheetmetal cover covering the flywheel. Undoing two or three M6 size screws should do it.
Posted: 04 Nov 2006, 04:51
by keegan
thanks heaps william, i missed those tiny little screws, the two are now apart
i am now planning to give both the gearbox and engine a very thourough clean. Clean and repaint some engine pulleys, replace the timing belt and retourque as many bolts as i can
while the engine and gearbox are out could you suggest any other maintenance/problem area's i should look at ? thanks :)
Posted: 05 Nov 2006, 20:17
by william vd Sman
Change the clutch and bearing.
Change camshaft oilseals and distribution belt.
Modify sump following guy crofts instructions (www.guy-croft.com). also some other mods can be incoorperated.
Good luck!
Posted: 06 Nov 2006, 02:14
by Randy Adams
Renew the shift linkage bushings if they haven't already been upgraded.
Posted: 08 Nov 2006, 19:51
by Angle grinder
Check on the condition of the short rubber pipe between the crankcase and the oil separator for the crankcase breather pipes.
Posted: 11 Nov 2006, 03:08
by keegan
thanks for the advice William, Randy and Mr. Grinder :)
i just sanblasted the water rails and found some pinhole leaks, what a slut :(
