driveline shunt
CD's with workshop manuals, parts book and other documentation
gary wilton
driveline shunt
Unread post by gary wilton »
I'm told that the driveline shunt (engine moving backwards and forwards when letting clutch in and out) on my HPE is normal - is that the case. It's pretty severe. You get used to it driving but it scares the pants of anyone who borrows it. Won't new engine mounts help?
Hamish
Re: driveline shunt
Unread post by Hamish »
Gary,
If the mounts have been replaced and its still 'shunting' then there's a problem somewhere. If all mounts and bushes are in good order then there should be very little driveline shunt.....
Hamish
leo capaldi
Re: driveline shunt - check the subframe mountings!!
Unread post by leo capaldi »
Hello Gary,
The worry about this is that it may be the subframe that is moving! I'm sure you know the legend.
Jack up the front using the standard jack points and see if the subframe hinges downwards.
Good luck and fingers crossed, Leo
Hardy Walker
Unread post by Hardy Walker »
Also check the condition of the two dampers that are present on the Beta it has one ar the Engine end of the Drivetrain package and one at the Gearbox end. If these dampers are worn out you will experience severe shunt.
Return to “61 Beta, Beta spider, Beta Zagato, Trevi”
