Valve Clearance and timing
Posted: 04 Jun 2008, 20:34
Dear all
I thought I new how to do this (setting the valves and timing), but having had one bent valve I am now nervous and decided that I am rather useless! I have read the forums, but am very confused. I have seen the 2.2mm 'thread', but cannot work out at what point on the rotation to measure.!
I know the old rule wont apply, and I have tried with a small bulb across the coil, showing when each cylinder is firing, but then I get confused as to which valves to check and whether to use 0.15 and 0.25mm as opposed to the 2.2mm.
I can set TDC for #1 and obviously that is the TDC firing of #4 - so presumably I should check the clearances at this point on #1 and #4, using 0.15 and 0.25mm.What I cant then figure out, unless I use the bulb is TDC for #3 and #2. But if I use the bulb, this would be the ignition point and not TDC?
I appreciate that there have been threads about this, but I am none the wiser. I have the manual and spec, but cannot translate into practice. An idiots guide would be appreciated before I do any damage!
thanks
Mat
thanks
Mat
