Hi all,
As the subject says, my indicators are not working, when moving the stalk nothing at all happens, I hear no relay click, nothing. If I press the hazard button I hear a relay click but again nothing happens.
Not sure which fuse is used for the indicators.., shared with the side lights perhaps?
Where is the flasher unit/relay for the indicators?
Thanks in advance for the help!
Indicator Lights not working...
Re: Indicator Lights not working...
Unread post by smokeme »
the fuse for the indicators is in the fusebox, the relay is the first one on the top left corner.. i'm having a similar problem, diference is nothing clicks on mine, stalk works though as tested with a multimeter...
