Kappa 20V Turbo coolant bleeding screw(s)
Posted: 10 Jan 2010, 13:47
by Mogensen
Greetings from Denmark!
I am sorry I write in English but my German is so poor that it would take a very long time to write a german letter here! And the English viva-lancia forum seems dead.
I need to change the coolant fluid and to drain it out I would pull of the thick coolant hose at the bottom right of the radiator (when facing the car from front).
QUESTION... Is there more than one bleeding screw when re-filling the system with new coolant fluid?
I have noticed only one bleeding screw (plastic) on the thick coolant pipe exactly to the left of the battery (when facing the engine).
Mogensen - Copenhagen/Denmark
Re: Kappa 20V Turbo coolant bleeding screw(s)
Posted: 10 Jan 2010, 16:43
by Zubrania
Hi Mogensen
To drain out the fluid you need to unscrew the plastic screw on the bottom left of the radiator (not an easy task). Let the fluid drain out. Then return and screw the plastic screw back. Then fill the reservoire with new coolant.
The next task is to make the air move out of the system.
You need to use 2 bleeding screws to do it
First one is located on the right up side of the radiator. Another one - on the hose of waterpipe to the heating radiator.
if you have ane questions - mail me to dzmitryj@gmail.com
Dzmitryj
Posted: 20 Jan 2010, 21:23
by Wichmann
Hej Mogensen
Ich bin auch aus Dänemark und habe auch zum Glück das Deutsche Lebendige Forum gefunden.
Das Englische Forum ist wahrscheinlich so tot weil der Kappa nie als Rechtslenker geboren wurde...
MfG
Ole W.
1996 Kappa 2,0
