Appia engine main bearing size
Posted: 29 Jan 2009, 21:55
Greetings All,
I am just starting the rebuild of my series 3 Appia engine. It came in several boxes with lots of spare parts and I am in the process of sorting through them and finding out what is good and what is not.
This is my first Appia engine and I have a couple of questions regarding the main bearings. First, I have an Appia shop manual on loan from a friend. I cannont find any specification for the diameter of the main bearing journal, I can only find a "sketch" specifying the assembling clearances. This shop manual is missing the first few pages - the first page present is 00/5. Could the crank bearing specs be on one of the missing pages?
I have a copy of the Automobile Engineer article about the first series Appia engine. It states that the main bearing diameter is 55mm, but I would like to confirm that this is correct for the series 3. Also, I would like to know if 55mm is the diameter of the journal or the bearing. My crank journals measure 54.22mm with a digital caliper. I am going to find a micrometer to make a more accurate measurement. Two or three sets of main bearings came with the engine, but each one has part or all of the indium lining worn off, so I assume I need to find new bearings - unless it is possible to have the lining renewed.
Many thanks,
Dave
Many thanks,
Dave
