Fulvia Funny behavior
Posted: 19 Apr 2004, 14:06
by christos skriapas
Hi lancisti
I don't know how to describe the behavior of my early restored Fulvia. The car runs well but evey time I'm trying to accelerate (any gear) it's moved back and frond and it's very annoying when it's doing that. so I'm talking for a 1.3 II serie but with prepared engine. My mechanic told me that propably is the main engine mount. I replace all the rubber mounts but the problem still exist. I was thinking about the small metal mount at the right side of the engine. That leg is adjustable but I've here nothing about the proper adjust.
Any note will be helpfull. I check all the fuel and electrics parts and seems to work ok
Thanks in advance.
Christos
Re: Fulvia Funny behavior
Posted: 19 Apr 2004, 16:21
by Huib Geurink
A possible cause may that the outer cable of the throttle cable is just too short. When accelerating the engine rotates a bit and thus influences the throttle if the cable is too short.
Posted: 19 Apr 2004, 20:34
by Paul de R. Leclercq
The little engine steady on the right should be adjusted so that it just touches the sub frame; it should not be tight against it.
Next check the central gearbox mount (the big circular rubber at the back of the engine above the gearbox). This may be fine, but it is quite common for what we call "The Eiffel Tower" (bracket underneath) to crack - sometimes in a way that is difficult to see.
Cross and longditudinal members can also crack and cause all sorts of trouble; I seam-welded all mne years ago!
Paul
Posted: 24 Apr 2004, 06:16
by Jim
There should of course be a rubber bush beneath the threaded stabilising arm to reduce vibration. As Paul says this should be adjusted so that it is just touching the subframe.
Also, how about the outrigger mountings at the rear of the front subframe - have you checked them where they join to the front of the sills?
Posted: 29 Apr 2004, 14:02
Thanks guys for the information. I'll chek this weekend. I thing the problem is what Paul said for the small mound at the right. No I remember that the problem starts the time I tight the leg against the frame.I' ll let yoou know.
Thanks again
christos skriapas wrote:
> Hi lancisti
> Thanks in advance.
> Christos
Posted: 29 Apr 2004, 14:11
Thanks Huib
I'll check this one as well. I'm planing to send the solexes to Omicron for refubiching but later because now I'm out of money. Until that my mechanic suggest me to replace the needles from 180 to 200. He said that the problem is the rich mixture of fuel. Any way I'll try all this weekend.
Thanks again
