Page 1 of 2
olie verwisselen (humor)
Posted: 09 Feb 2006, 16:56
by Bob
voor mij zijn hier wel dingen herkenbaar:
Women:
1. Pull up to Jiffy Lube when the mileage reaches 3000 since the last oil
change.
2. Drink a cup of coffee.
3. 15 minutes later, write a check and leave with a properly maintained
vehicle.
Men:
1. Go to O'Reilly auto parts and write a check for 50 dollars for oil,
filter, oil lift (AKA kitty litter), hand cleaner and scented tree.
2. Discover that the used oil container is full. Instead of taking back to
O'Reilly to recycle, dump in hole in back yard.
3. Open a beer and drink it.
4. Jack car up. Spend 30 minutes looking for jack stands.
5. Find jack stands under kid's pedal car.
6. In frustration, open another beer and drink it.
7. Place drain pan under engine.
8. Look for 9/16 box end wrench.
9. Give up and use crescent wrench.
10. Unscrew drain plug.
11. Drop drain plug in pan of hot oil; get hot oil on you in process.
12. Clean up.
13. Have another beer while oil is draining.
14. Look for oil filter wrench.
15. Give up; poke oil filter with Phillips screwdriver and twist it off.
16. Beer.
17. Buddy shows up; finish case with him. Finish oil change tomorrow.
18. Next day, drag pan full of old oil out from underneath car.
19. Throw oil lift (AKA kitty litter) on oil spilled during step 18.
20. Beer. No, drank it all yesterday.
21. Walk to 7-11; buy beer.
22. Install new oil filter making sure to apply thin coat of clean oil to
gasket first.
23. Dump first quart of fresh oil into engine.
24. Remember drain plug from step 11.
25. Hurry to find drain plug in drain pan.
26. Hurry to replace drain plug before the whole quart of fresh oil drains
onto floor.
27. Slip with wrench and bang knuckles on frame.
28. Bang head on floor board in reaction.
29. Begin cussing fit.
30. Throw wrench.
31. Cuss for additional 10 minutes because wrench hit Miss December(1992)
in the left boob.
32. Clean up; apply Band-Aid to knuckle.
33. Beer.
34. Beer.
35. Dump in additional 4 quarts of oil.
36. Beer.
37. Lower car from jack stands
38. Accidentally crush one of the jack stands
39. Move car back to apply more oil lift (AKA kitty litter) to fresh oil
spilled during step 23.
40. Drive car
Re: olie verwisselen (helaas geen humor)
Posted: 09 Feb 2006, 17:42
by Marco
Afgelopen zondagmiddag t.h.v. Baden Baden ................
http://img212.imageshack.us/my.php?image=vs24kw.jpg
Groeten,
Marco
Posted: 09 Feb 2006, 18:06
by Joop
Da's kl.......... en nu?
Posted: 09 Feb 2006, 20:44
by Marco
Hoi Joop,
Inderdaad kl....! Mijn tank staat nog in Duitsland (op zich geen gekke plaats voor een tank) en komt eind volgende week per ANWB naar huis. Daarna wordt de boel opengeschroefd en door Renault bekeken.
Afwachten dus.
Trouwens, hoe zit het met de naafdoppen?
Groeten,
Marco
Motor opgeblazen......nu ridder te paard!
Posted: 10 Feb 2006, 17:54
by Joop
Wordt geregeld , was helemaal vergeten op te sturen.
Gaat as maandag op de post.
Blaas net zelf mijn motorop ben nu ridder te paard geworden......loopt op 2 cylinders nu mijn boxertje
tja mijn 33tje heeft last van lekke koppakking...
Ga nu maar effe paar weken fietsen is nl ook nog eens gezond ook, mijn werk is vlakbij dus dat is
niet erg.
Omdat mijn 33 te goed is voor sloop ga ik het motortje wel reviseren duurt wel ff voordat klaar is.
Gr,
Joop
Re: Motor opgeblazen......nu ridder te paard!
Posted: 10 Feb 2006, 19:12
by lucas
Tja,
Wat moet je ook met een alfa? Of is het een vaderlandse truttenschudder met jarretel aandrijving?(daf)
Lucas
Posted: 11 Feb 2006, 22:07
by Joop
Hoi Lucas,
Tja dat kocht ik bij gebrek aan beter bij mijn werkgever welke Alfa en Fiat verkocht, en service aan
Lancia's verleend. Men had geen lancia staan...ja wel een Thesis maar die lag net buiten het budget
en mijn 33je is verder helemaal origineel (Geen roest.....:-) .
Bij inspectie vandaag blijkt dat 1 van de cylinders overslaat .dus dat wordt alle bougie's nakijken cq
vervangen als ook alle vloeistoffen en dan zou het goed moeten zijn, misschien nog nieuwe bougie
kabels monteren.
Overigens vandaag Klassiek en Techniek gekocht staat een artikel in over Lancia Fulvia ivm onderhoud
e.d. Is maar een half bakken verhaal vindt ik zelf, schrijver had zich meer moeite moeten doen om met
wat betere feiten moeten komen over de verschillende dingen die worden geschreven..
Wel leuk dat er geschreven wordt over de Fulvia natuurlijk.
Groet,
Joop
Posted: 11 Feb 2006, 23:56
by Peter Coolsma
Heb dat artikel ook gelezen. Ook hier weer dezelfde, vaak gemaakte fouten/foutjes (alu motorblok bijv.) en veel kop-noch-staart-info. Er wordt wel gerefereerd aan de LCN-site - waar je notabene hoegenaamd geen concrete info over Fulvia-techniek vindt - maar VL wordt niet genoemd.
Posted: 12 Feb 2006, 11:04
by Mathias
Hoor ik daar een brief aankomen met alle fouten opgesomt die verstuurd zal worden naar de redactie??? :P :D
Posted: 12 Feb 2006, 11:28
by Marco
Zoals een groen/gele streep over de auto?
