Page 1 of 2
Coupe Door Panels
Posted: 05 May 2007, 17:46
by Gus
Hi All,
Some rotten swine forced a wing mirror and broke it a few nights ago. I would like to check out the mechanism to determine of it can be fixed before spending £200+ on a replacement. Now the question is how to remove the red reflector on the rear of the door panel. This has to be done (well I think so any how) to gain access to the last screw keeping the attached to the door.
Your help will be appreciated! I'm hoping someone is online now in fact ;O)
Thanks
Gus
Re: Coupe Door Panels
Posted: 05 May 2007, 21:53
by Lindsay
Use a screwdriver and brute force Gussie! Or get your wallet out. Do what I do. Buy a £600 Citroen estate and keep the K safe in the garage :o)
cheers
LR
Posted: 07 May 2007, 20:13
by Karsten
Haha Lindsay is right about "brute force"... right after we bought the Kappa 3 years back I decided to remove the door panels because of some sqeaky sound (never found anything and was gone when I screwed the panel back on?)...It took more than half an hour to figure out where all the screws where inlcuding the ones hiding under the 2 little rubber dots in the handle (driver's door).
Posted: 10 May 2007, 05:23
by Duarte
Hello,
Sent you a .pdf file showing how to do it. Check your e-mail. If you know some dutch or german it might help :)
Posted: 10 May 2007, 08:37
by Gus
Many thanks for all your comments. The panel was removed and replaced with minimal damage (lug tab to reflector snapped).
Until the next time,
Gus
Posted: 18 May 2007, 20:13
by Angle Grinder
Well done Lindsay, it seems you actually gave some constructive advice. Albeit unintentionally!!!
Need to get you a position as technical adviser to the Kappa Coupe Consortium. LOL
Posted: 19 May 2007, 14:47
by Karsten
Angle Grinder and Lindsay...
How many paintjobs have you scratched when your Lancias met out there in the real world!
Posted: 23 May 2007, 18:18
by Angle Grinder
Hi Karsten,
Its all in jest. Lindsay and I actually have a 50:50 share in the same car and we're good friends.
I just don't trust him with a spanner and wouldn't let him change the car mats on my car!
:0)
Posted: 24 May 2007, 17:08
by Karsten
Haha... what car is that?
I am guessing it is neither a Kappa nor a Thema (unless its a 8.32)...
Posted: 24 May 2007, 18:50
by Gus
You should see the guys with spanners in their hands - a sight to behold! :o)
Are we going for the longest unrelated tread in this forum.
Gus
