Refitting Fulvia headlamp switch
Posted: 21 Jan 2025, 19:43
I'm really struggling to refit my Fulvia (S3) steering column headlight switch. The small rollers which (I presume) operate the self-cancelling mechanism appear to be pressing too heavily on the steering column itself and this in turn is making it impossible to seat the switch properly in the alloy casting in order to locate the large brass locking ring.
I've seated the small metal tab on the domed metal casing which ensures the switch is in the correct orientation and so I know that's not the cause of the problem.
Is there some significance to the amount of shims/washers which sit under the retaining collar which locates the switch into its domed metal casing?
