Fuel pressure setting for King filter
maurice.lanciste
Messaggio da leggere da maurice.lanciste »
Hello !
For Lancia Flavia Coupé 1800 type 815330 - Solex 32 PAIA 8 carburettor - Facet 480530 fuel pump.
Project for mounting a KING filter regulator.
[b]- What fuel pressure setting ?
- What diameter for the carburetor needle valve?[/b]
Thank you very much
Maurice
gcarenini
Re: Fuel pressure setting for King filter
Hello Maurice,
You are right, the pump you mentioned generate a too high pressure, I suggest to use a Facet 477060E that is just the same as the factory Bendix/Pierburg installe by Lancia, that not need any regulator nor carburetor modification. I use that pump on my Flavia and Flaminia.
Best regards
Giovanni
grifo63
Hi Maurice, needle valve for Solex 32 PAIA 8 Flavia carburator is 1,75mm.
maurice.lanciste
Thank you for the clarification.
Best regards
Maurice
Torna a “Flavia e "2000"”
