how to Adjust Series one column gearchange
Posted: 16 Jun 2016, 20:24
by fay66
Can anyone help please with how to adjust the column gearchange on series 1 GT Berlina for a friend in Australia, he can't get first and second gear, and working out how it all works is a bit difficult.
The workshop manual isn't much help I'm afraid
Brian.
Re: how to Adjust Series one column gearchange
Posted: 04 Oct 2016, 13:48
by Jean de Barsy
It's probably due to worn plastic caps. Check the rods and you will see there are plastic "cups" you can tighten to take out the play.
If there's play, it will not work properly.
Posted: 04 Oct 2016, 13:59
by Huib
Jean is right. There are some plastic parts (cups, washers) in the system. The plastic from the 60's is much less stable than todays plastics. The parts will crumble or already have. Replace all the plastic parts and you have a different gear change
