Thema Turbo 8V 1989: headlamp/ suspension bearing/ fuel/ manual
Optimist
Unread post by Optimist »
Does anyone know the exact headlight part number for my Thema Turbo 8V, one than has the recess for the light sensor?
And Where can I get a top suspension Bearing and Housing for the top LH suspension strut?
Finally, The car surges when going up hill or accelerating past 3500rpm. Suspect fuel, any ideas?
My electrics are a mess, ant workshop manuals available?
Regards
Lindsay
Re: Thema Turbo 8V 1989: headlamp/ suspension bearing/ fuel/ manual
Unread post by Lindsay »
Thema Consortium has the full workshop manual, including electrics. Can send the right bit to you if you join!
cheers
> Regards
Mike
Unread post by Mike »
For the top suspension bush you could also try Betacar... CHRISBASTO@aol.com
I believe it is the same as the Fiat Croma part.
Return to “51 Thema”
