Fuel pump
Posted: 09 Nov 2001, 23:04
by Odd Erik
Does anyone know where the fuel pump is on the car?
Is it hard to get a good look at and maybe change?
Thema ie. -86
Re: Fuel pump
Posted: 11 Nov 2001, 17:37
by adam
The fuel pump sits inside the fuel tank.If you take out the boot carpet you will find a metal panel screwed to the floor between the rear seat and the spare wheel well,under this is the fuel tank . There are two plastic ring nuts,the small one is the tank unit for the gauge,the other one is the pump.GOOD LUCK..
Re: Fuel pump
Posted: 12 Nov 2001, 23:38
by Odd Erik
The grounding (-) of the fuel pump. Is this situated at the back of the boot? in the back of the spare wheel space?
Re: Fuel pump
Posted: 16 Nov 2001, 22:17
by adam
Yes you are correct,cut off the old connectors and fit ring terminals and bolt them to the earthing point using the 13mm bolt.This should stop you having any problems with the earth for the pump.
