Klima
Posted: 04 Jun 2014, 17:14
by cavaradossi
Pünktlich zu den bevorstehenden hochsommerlichen Temperaturen spinnt die AC
Wenn ich den rechten Knopf für Klimaautomatik drücke, passiert nichts, es bläst nur die Voreinstellung
f. Windschutzscheibe ohne Kaltluft
(Ob da meine Beifahrerin reingepfuscht hat, sie mag es nicht kalt?)
Linke Seite funktioniert zum Glück
Kennt jemand das Gebrechen?
Re: Klima
Posted: 04 Jun 2014, 18:57
by vlad47
The problem is the electric motor on the climate control. It's a pity I've forgotten to take the picture when repairing it in my friends thesis. It's quite complicated to get there. You have to disassamble the glovebox and also take out the passenger airbag and there still won't be enough space as you wish. There are 3 motors on each side, your problem is on the right side, but I can't remember which motor is for mixing air. You should try. And the problem is that the motors are not produced in Italy, they are bosch. When you open the case you will see that they were too lazy to solder the motor connection to the pins and they are only pressed together. So after some time it simply moves away. You will see what I mean after disassemling :) Good luck.
Re: Klima
Posted: 16 Jun 2014, 09:20
by cavaradossi
Vielen Dank für Hinweise,
nun, zum Glück kann ich mir den Ausbau sparen, es war nämlich Klimafunkton rückwärts (rear)
eingeschaltet, offenbar verhindert diese Funktion, dass gleichzeitig auf der Beifahrerseite
Änderungen (full auto, Gebläserichtungs- od. Temperaturänderung) vorgenommen werden
Also alles iO
Re: Klima
Posted: 16 Jun 2014, 10:41
by vlad47
That's correct, only one can setup the second zone :)
