Dedra Turbo Battery Light
Posted: 23 Apr 2003, 14:51
Hello all,
as usual my dash seems to be playing up again or is it??
I noticed the other day that with the ignition on the oil, abs, handbrake etc light come on but the battery doesn't. Suspecting it was simply a bulb I swapped it, including the holder, with the oil one as I new it worked. Powering up again still no battery light but oil on so I know both bulbs were OK.
The battery charges ok, although the needle only goes upto 9-10 volts, when the engine is rev-ed to about 3 thousand or so the needle then jumps to about 12 and stays in that area.
What I'm not sure about then is whether I have a problem with the dash itself, the altenator or in fact by some funny quirk of Italian logic the battery light should come on at all? Except for if the altenator fails and the battery voltage falls to low.
Anyone any ideas?
Many Thanks,
Gary
Anyone any ideas?
Many Thanks,
Gary
