How do I check the oil or replace the oil in the rear differential on my Delta HF Integrale?
I believe I'm having some problems with my turbo; when accelerating fully i.e. 2nd gear, shifting to 3rd using full throttle and full turbo boost, the turbo kind of cuts all the power. I then then have to go off the pedal and start over again...
Could it be the throttle potentiometer of something like that? This only happens when having full turbo boost...
Turbo overboost and checking oil level at rear differential
delta hf turbo
Unread post by paulo caeiro »
i boght a 1.6 hf turbo dammaged to change some parts the electric sistem its burned out the version of the motor is 831ab016 how can iknow the thecnical characteristics of the motor?
can i change my delta 1.3 l.x 1991 motor for the 1.6 hf turbo
can y adapt the 1.6 complete admission to the 1.3 motor [adapt the turbo}
1'3 is ohc 1'6 is dohc
the rear suspencion whith brakes sistem its possible to adapt to the 1.3 delta
Return to “57 Delta, Prisma, Delta Integrale”
