Delta HF turbo 32/34DMTL carb?
Posted: 07 Apr 2005, 20:10
by FASTdan
Hi chaps,
This is my first time on here as Im not a lancia man, but a ford man (awaits the stoning lol)! anyway im after a bit of info regarding the HF turbo's carb. I'm told its a webber twin choke 32/34 DMTL, is this right? Basically I run a mk2 fiesta XR2 with a turbo technics kit which uses a webber 32/34 DFT, however upon pressure testing i have found this carb to have numerous leaks, including the throttle spindles and choke spindle on the primary barrel - which are both fairly incurable really.
However i have a DMTL that i used to use on a NA XR2 and notice that it is near identical in design to my DFT. Soooooo what i was wondering was has anyone pressure tested a DMTL, do they leak much? Was the DMTL fitted to lancia's somehow enhanced to cope with boost? maybe a seal kit as found on the turbo versions of the DCOE?
I find it hard to believe that a company like lancia would produce a turbo car with a leaky carb, but from what i can gather from my 2 examples the DMTL is pretty much identical to the DFT.
Also anyone got a picture of the plenum chamber? I'm seriously contemplating trying out the DMTL but my plenum would require some minimal mods to fit so I'd rather use a purpose made one if possible.
Any help would be much appreciated
cheers
Dan
