Stossdämpfer (Skyhook) hart......
gergely
Re: Stossdämpfer (Skyhook) hart...... **Problem gelöst**
Unread post by gergely »
Hi Thesis friends,
where is this ECU component located?
Does this condensator has visibable damage (swelled)?
Thanks, Gergely
Gergely
Aleksandar Vidojevic
Unread post by Aleksandar Vidojevic »
Hello,
I would also like to contribute with my experience. One year ago I replaced all four shocks with brand new ones, since some front and rear shocks were leaking. Immediately after my mechanic mounted the new shocks the car (they came as gas shocks), we got SKYHOOK Error on the dash display. The error did not appear most of the time, but it keep coming on some elevations etc. Nothing too worry about. I also noticed sometime some strange creaking when the car passes speed bumps. Anyway, last Saturday, my mechanic replaced water tank, timing belt and serpentine belt, and since than SKYHOOK error does not go away. ALFAOBD diagnostics shows C1201 error at front right shock (valve error etc). The mechanic checked the power supply and the shock gets electricity. I purchased the shocks from Fiat dealer in UK, not sure if I could claim any warranty protection since I did not installed the shock in Fiat. It is strange that the shock worked on most of the time. It looks like a wiring problems. We checked connectors and everything seams ok. Does anyone have any idea what could cause the problem?
The car is not extra firm since the ECU set it in a safe mode, since there is error coming from one shock.
By the way, I changed the SKYHOOK capacitor two years ago. It really helps.
Best,
Aleksandar
themav6
Unread post by themav6 »
Hallo Gemeinde
nun hat es mich auch erwischt :X
Habe die Kondensatoren gewechselt nix gebracht
(Kalte Lötstelle) eher nicht
nun bin ich am Rätzeln
Kann es sein das die Sensoren doch nicht soooo dicht sind?
habe das Problem immer gehabt wenn ich mit dem Auto in der Waschstrasse war
nun ist es dauernd an.
danke und viel Spass mit der Diva
Themav6
Return to “D30 Thesis”
