Compression failure
justin
Re: Compression failure
Unread post by justin »
You may find a bent valve has a memory!
If you can simulate the reverse of the moment of collision with whatever may have caused the damage, you may well find it will repair itself to the original shape, or at least close enough to re-cut and seal.
Don't want to sound like I'm very clumsy, but I have succeeded several times with this repair!
You know they're all on about recycling everything, so here's your chance!
Good luck!
Jus
mat
Unread post by mat »
Many thanks all. Now running.
Thanks for the comment justin, I might try this on an old head and see!
mat
Return to “65 Fulvia”
