Latest I can reveal is half a litre of mayo in the top of the head with rocker cover off.
Water pump drains not blocked and no sign of leaks / water in cyclinders (cranked with plugs out).
So off with the head.
Nothing very obvious from the gasket as its only been in for 500 miles so I will get the head to my machine shop and look for warping (favourite).
Tim
Water loss
Re: Water loss
Unread post by tim »
Update for those interested.
Took head off - nothing suspicious regarding the head gasket.
Stripped head and took to Cober Engineering - a specialist cylinder head engineering shop.
Pressure testing showed big leak from inboard middle inlet cam cap bolt which was threaded down to the waterway. This would not have been a problem if the previous repair had not cracked away the surrounding alloy.
Repair in progress with an aluminium plug tapped and welded into place - cracked metal removed and rewelded.
I await a further leak test to confirm no other problems before 3 other cap bolt threads are repaired!
Tim
Tim
