Wood dash
Ralph deMasi
Re: Wood dash
Unread post by Ralph deMasi »
Rick,
I actually veneered a plastic S2 dash for my S1 Fulvia Coupe this past summer. I had just replaced my leather covered steering wheel with an original S1 wood wheel and so wanted to have the dash match the wheel. I purchased the veneer at Certainly Wood I believe and it really did come out nice in finish and grain match. I try to find the name of the wood so you can look at it on their site. I think it was a type of Brazilian Teak.
I have a large piece of the veneer left because you're forced to purchase a certain size and so I think I have enough to do another dash. I would be willing to send you the piece for the cost of the shipping or if you want you could send me the dash and I'd be willing to do it for you. In the case of the first solution I need to find the glue I used so I can tell you what type to use and if you give me a day or two I'll send some photos.
Ralph
Rick
Re: Wood dash
Unread post by Rick »
Wow! how can I refuse a deal like that! Sharing your experience with the group would be really nice. I assume you are in NY and I'm in MA at 02648 if you want to send me the material.I can send a check or Paypal. We can follow up off line. Thank you!
Ralph deMasi
Re: Wood dash
Rick,
I used Wellwood contact cement. You'll want to sand the face of the plastic dash a bit so the glue can grip. You'll also want to keep the two clamped together till it dries. I then used a new razor to cut around the openings and the outside. Work slow and be mindful of the direction of the razor and the grain in that particular area as you can easily pull out fibers from the veneer. You can then go over all the edges with 200 grit sandpaper.
I used several coats of shellac, I think it gives a more natural, organic look. If you prefer you can try polyurethane.
By the way the wood is Jatoba. If you Google it you will see all sorts of photos but I suggest you look at it on the CertainlyWood.com website.
I'll PM you further details.
Ralph
Return to “65 Fulvia”
