Page 2 of 2
Re: Failing helicoils - rocker shaft caps - What now?
Posted: 08 Jul 2009, 22:12
by lancialulu
Throw the bolts away and use studs as per Aurelia's Then you are tourquing down on the stud thread!
Amazingly I had forgotten this was part of my repair solution!!!!!
Note I mention Aurelia as they have the M8 fine thread as per Fulvia (at one end or both- which I cant remember!!!!!!!!!!!!!!!!)
Tim
Posted: 09 Jul 2009, 15:28
by Peter de Wit
And you solve the length problem....
Posted: 09 Jul 2009, 15:37
by lancialulu
exact!
Posted: 09 Jul 2009, 16:31
by Bart Verbeek
In a factory where the magic words: [s]arbeit mach....[/s] I mean "Over-engineering is serious business" (in Latin of course) are written above the front gate, the responsable for those bolts (and the neverlasting helicoils) should be still in prison!
Posted: 10 Jul 2009, 08:34
by racing
Solutions of this are alway driven by the cost´s.
This is the reason why Lancia comes 1969 to Fiat.
Andreas
Posted: 10 Jul 2009, 12:18
by Bart Verbeek
That's why it was the slogan for the engineers. Cars nowadays are designed by the enviromental and the financial department in stead of those technical engineers.
BUT, I got my head back (the 302-head it is
) and 5 helicoils were changed. Total cost: 131€. They even gave me new bolts.
Hopefully everything goes according to plan now, so the engine can be mounted in the berlina this weekend.
thumbs up! (tu)
Posted: 25 Jul 2009, 22:52
by VAR1016
Sorry, no time this evening to read all the replies.
At Evolution Engineering we naturally used to come up against this all the time.
I decided that the problem is caused by some sort of crystalline deterioration of the very hard aluminium alloy that was used by Lancia - the material seems to crumble around the Helicoils.
Normally we would use 8 x 1.25 Timeserts, but sometimes the damage would be too bad. What we did then was to order 10 x 1.25 Timeserts for which there would usually be enough good "head" left (!) and then simply screw an 8 x 1.25 Timesert into the larger one.
The one exception I can recall was on the head in my own engine which had a real problem. For this I drilled and tapped the hole to 14 x 2 and the ever wonderful Phil got on his lathe and made me a an 8mm stud with a 14mm end! I fixed the cap with a Nyloc nut. I doubt if it will ever come out!
On the Fanalone I have mentioned elsewhere I had this problem; I was working on the car at a garage in Switzerland near Nyon. Timeserts wouldn't do - or rather I couldn't get the ones I needed. the owner of the garage had friends at Heini Mader's establishment down the road and came back with a wonderful and costly kit with beautiful stainless steel inserts. Sadly I cannot remember what they were called, but the did the job very nicely.
Paul
Posted: 25 Jul 2009, 22:54
by VAR1016
> thread!
> Tim
Fine, but you won't be able to remove the exhaust side parts with the engine in the car!
Paul
Posted: 31 Jul 2009, 23:47
by lancialulu
Paul
I wasnt refering to the exhuast ports, only the cam caps.
Tim
Posted: 31 Jul 2009, 23:50
by lancialulu
Paul
I seem to remeber you put one of your heads on my engine (ex Postlethwaite) and one of the studs did fail which is why i had to have it welded back up as the stud came out with a 14mm end to it!! I'll send you the invoice!!!!
Tim
