Re: Electronic Veglia rev counter
Posted: 17 May 2016, 15:20
Huib Wrote:
> Did you connect the wire for the rev counter to
> the wire coming from the points or to the -
> (minus) terminal of the coil?
> I offer an electronic distributor on this site.
> See
> http://www.viva-lancia.com/specials/ignition/index
> .htm.
> The rev counter works with it.
I have tried all different combinations of wiring, the rev counter (Veglia, berlina) needle will jump a little but not register the revs. I can't afford a new distributor. Could there be a fault with the ignition amplifier in the Sparkrite? I have tried another (Yazaki) rev counter and it does the same thing, very low erratic readings when switched on to the electronic setting but works on the points setting.
> See
> .htm.
