Page 2 of 2
Re: Brakes remain on
Posted: 04 Oct 2001, 11:24
by carlo venturi
Hello Huib,
how you do know the front left brake hose on my Flavia cpè went blocked after braking. It worked like a one way valve and I had to wait a long time for having the disc loosened. I dismantled front brakes several times before I realized it was a brake hose. The tip I can say to all of you if the car pull over, is to check the front calipers. If there is not a lot of brake fluid leakage when loosening the bleeding screw on the caliper, you can start to blame hoses. Ciao, Carlo
