Thesis Car-PC Project Reloaded
Re: Thesis Car-PC Project Reloaded
Hi, you are doing too much complicated. Don't use any iso or other cable. Just let the changer connected and only cut the audio cables from it. So in the connect you turn the changer on and it starts, only the audio won't be from it but from your computer. My external sound card has cinch co I have soldered a cable with cinch there and other cable with highjack (3,5 mm) for the input to the computer from the changer. Extracting the changer was a mistake, put it back
Lancia Thesis 3,2 V6 + LPG Emblema 2007
Lancia Thesis 3,0 V6 Emblema 2004
Lancia K coupe 20VT 1998
Lancia K coupe 20VT 1999
Alfa Romeo Spider 3.0 V6 12V Lusso 2000
ICQ: 312857200
e-mail: vladimir.duro@lanciathesis.eu
Phone: 00421-907/087956
www.facebook.com/lanciathesiseu
www.vialleslovakia.sk
If you have any problems with your thesis, feel free to contact me.
ICQ: 312857200
Amici, can somoeone point me to a person who'd organize me this?
https://www.youtube.com/watch?v=7042xN37f-0
Lancia Thema 3.0 V6 CRD Executive Luxury Brown (2011)
Lancia Delta 1.8Di Platino Executive Bicolore Bronza/Nero (2010)
Piaggio Vespa PX200E Arcobaleno 12PS (1986)
ex Lancia Thesis 2.4 JTDm Limited Edition Grigio Rossini (2007)
ex Lancia Delta 1.9 TwinTurbo MJet Executive Nero Etna (2013)
Hm I thought about that but what if my CD Changer doesn't work or partially doesn't work? I mean it recognizes the changer but it doesn't read CDs (always "No CD").. Am I right, that in this case this solution doesn't work? If my assumption is right, I'll have to buy the loudlink cdc Emulator..
Looks nice, but I think he changed the Display and you Need some Kind of KVM-Switch to Switch between the Android PC and the original Thesis Connect.. If you understand german, you can start here:
http://www.thesis-treffen.de/index.php/ ... arpceinbau
You want to DIY or you are searching for someone to modify it for you? This will be a lot of work, I think vlad47 is the Guru on this Topic
Hallo Gregorio,
ich habe dir vor langer Zeit auf dein Video bei Youtube geantwortet,kam aber keine Rückmeldung von dir.Wäre nett wenn du dich mal per Privat Nachricht bei mir meldest danke!
Mücke schrieb:
> Hallo Gregorio,
Ups,jetzt erst richtig gelesen das du den Salvatore Macri auch suchst!Post kann gelöscht werden von mir!Sorry
> Hallo Gregorio,
I know the question is a bit stupid but did you put the cd upside down? Because that is the correct position.
ICQ: 312857200
ICQ: 312857200
No, this ain't a stupid question and the first time I tried the changer, I did put it in the wrong way.. But after reading the Manual I tried it with the Label down and it didn't work either.. So I don't know whats wrong with the charger but I think for your solution the changer has to be working and a CD has to be running.. So last week I ordered the Loudlink box, which should do the trick..
Btw. just changed the arm rest, so much fun
Yes you are right, if you want to do it the same way I did your changer needs to be working. If using loudlink than it has directly a highjack input
I know exactly what the armrest change means hh.
ICQ: 312857200
ICQ: 312857200
