Overboost?!
giovanni
Re: Overboost
Unread post by giovanni »
Dear Nelson
Al the Turbo engines from Lancia 2.0 8v and the 2.0 16v have had a overboost system.There is only a big difference between the system of the 8v and the 16v.
Because the 8v can only make a pressure of 0.2 bar higher, and the sistem of the 16v can bring the pressure so high as you want dependend of witch software you use!!!!!
I drive in the pas with a special eprom max pressure was 1.6 bar till 4800rpm and it reduce till 1.4 This is also the maximum witch yot 16v turbine can have.
Giovanni
Return to “57 Delta, Prisma, Delta Integrale”
