Gearbox Oil
CD's with documentationElectronic distributor
lolomovil
Gearbox Oil
Unread post by lolomovil »
I'm going to make a gearbox oil change on my 4 speed gearbox and i'm asking what modern oil is better for it. ¿Api4 or api5? ¿Monograde or multigrade? Thanks.
LanciaFin
Re: Gearbox Oil
Unread post by LanciaFin »
Hi,
The original specification is probably API GL3. Do not use synthetic oil or one with EP-additives, they will harm the synchronizers. I use Tutela ZC90 in my Flavia.
BR,
Miika
lolomovil
Re: Gearbox Oil
Thanks Miika. I searched Tutela ZC90 in my local distributors and found that this oil is used on Iveco trucks today. I'm a bit confused as the fulvia and flavia has diff shared with gearbox and actual standards recommends API GL5 por hypoid gears, but as lancia gearbox is engineered with API GL3 in mind, i think this oil is ok for lancia diff.
Regards.
Ed Levin
Re: Gearbox Oil
Unread post by Ed Levin »
I've used full synthetic -- RedLine Lightweight Shockproof -- for over a decade with no issues whatsoever.
Return to “65 Fulvia”
