The engine block has cracked on my 1990 Thema 16V turbo.I have a low mileage 1987 8V turbo engine.
Would it be possible to fit the 16V turbo head onto the 8V turbo block?
Fitting 16v Thema turbo head to 8v turbo block?
Re: Fitting 16v Thema turbo head to 8v turbo block?
Michael,
I can't give you a definite answer on this, but when I did the head gasket on my 8v Turbo I was wrongly supplied with a 16v gasket and I noticed that there were differences in the aligment of holes in the gasket for coolant channels and oil feeds. Fortunately a friend had an 8v gasket so the job was completed without blocking any channels.
I would take a careful look to see how the two gaskets compare when you remove the heads.
Cheers
Cheers
Sorry about pointing to another forum but i think it has the answer on it.
http://turbo124.com/forum/
(in the 16v conversions section)
Been a member there for a while, basically any question that requires a bigger technical aspect will get an answer....
