Flavia trunk repair
CD's with workshop manuals, parts book and other documentation New: electronic distributor
bmw8890
Re: Flavia trunk repair
Unread post by bmw8890 »
I can see how this welded support (cardboard template in picture) attaches to the wheel well in the sent pictures but not sure how it attaches to the rear of the car (shown in blue)
welded fender side plate.jpg (88.56 KiB) Viewed 1044 times
grifo63
Unread post by grifo63 »
Ciao Brian, referring to the attached the "empty space" between the two walls continue, turning in the corner, up to the wheel mudguard.
x section flavia.jpg (195.41 KiB) Viewed 1044 times
bmw8890
got it thanks
bmw8890
The parts catalog shows a tool strap assembly attached to a baseplate and the reference pictures of a trunk show a strap assembly fastened to the trunk floor. What is the correct assembly configuration for the tool mount and does anyone have detailed information of this assembly to replicate the components (strap, strap bracket, and fastener size and location)?
grifo63
Hi bmw8890, I've this assembly on my Flavia berlina (sedan) but in the convertibile it is missing and neither the fixing holes are present; Moreover the spare part catalogue references are for 815.00 only.
However I appreciate it is useful tool, if you wish to add to your convertibile I'll post some details in the next days.
bmw8890
Thanks grifo63 that would be great
grifo63
hereafter some details:
4 is a soft rubber dumper plate
7 is a black painted thick natural leather belt approx 500mm lenght 30 mm wide
22 is a U iron profile 160mm lengh, 33mm wide hold by 2x M5 screws; the spare wheel colums nearest screw is 115mm far from it and all assembly is about 20° rotaded vs car main axle (see the picture).
cintura attrezzi flavia.jpg (197.33 KiB) Viewed 1044 times
bmw8890
Thanks grifo63 for the info on the tool kit mount.
Also need information on the rear exhaust mounting bracket that is welded to the U frame under the trunk, type/shape, dimension, and location relative to the rear leaf spring mount. Is the bracket similar to the other exhaust mounting brackets?
bmw8890
Attached pic shows ref. dimension needed...thanks
grifo63
Hi, I can't do this measurement at this time but possibly in a couple of weks or so; it may be someone can do faster.
Return to “68 Flavia, Lancia 2000”
