Hi!
I have seen in some service manual a picture that shows how headlight can be easily removed for Light bulb change. How is this actually done?
Voikkari
Headlight
Re: Headlight
Did you find answer for your question?
Max
Max
Re: Headlight
I have a strong feeling that this fellow Thesisti comes from Finland, so please check Finnish Fiatforum from here: Kokemuksia Thesiksestä
BR,
Jari
BR,
Jari
__________________________________
Lancia Thesis 3.0 V6 Emblema 2003
Plymouth Belvedere 2D HT 1958 "Christine"
VW 1200 1965
Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn!
VW 1200 1965
Re: Headlight
See the attached PDF file. The "special wrench" mentioned is an ordinary 5 mm socket, although you may need a universal joint (a swivel adapter). It's recommended to use a six-corner socket. I got a cheap 12-corner one stuck at the locking rod. Not that bad actually: the socket stays there and it is easier to locate than the hexagonal rod end rather deep inside the fender.
- thesis light cluster en.pdf
- (122.39 KiB) Downloaded 73 times
