Hello,
I have a problem with the anti-theft device in my Thesis... The alarm starts to hoot after a few minutes after I lock the car (without the reason). But when I disable the anti-lift sensor, everything is ok. My conclusion is that this sensor is not working correctly. Where can I found it? Or maybe I should check sth else?
Alarm - anti-lift sensor
Re: Alarm - anti-lift sensor
Hi,
you can find the reason of last hooting in a body computer viac diagnostics. The lift sensor is on the alarm board and it's situated in the front ceiling panel, the small board.
Lancia Thesis 3,2 V6 + LPG Emblema 2007
Lancia Thesis 3,0 V6 Emblema 2004
Lancia K coupe 20VT 1998
Lancia K coupe 20VT 1999
Alfa Romeo Spider 3.0 V6 12V Lusso 2000
ICQ: 312857200
e-mail: vladimir.duro@lanciathesis.eu
Phone: 00421-907/087956
www.facebook.com/lanciathesiseu
www.vialleslovakia.sk
If you have any problems with your thesis, feel free to contact me.
ICQ: 312857200
I had the same problem.
Lift sensor detector circuit dismounted, and still the same issue, when lift sensor not disable manually by button.
I think this is not lift sensor problem, this is voltage problem.
I disabled whole alarm using diagnostic sw.
Arnold - Lancia Thesis 3.0 Emblema - Alfa Romeo Spider 2.0TS
http://www.loudlink.eu - Cd changer replacement solid state car MP3 players for Alfa Romeo, Fiat, Lancia, Maserati, Porsche
How did you disable it? I would like to enable it. What diagnostics soft did you use? Alfaobd is not working when trying to enable, it fails.
ICQ: 312857200
ICQ: 312857200
please check water infliltration rear head units. I had the same; I ve closed the leak now everything ok. Check it out. Losen clean and tighten the 2 ground bolts m8 just underneath the the two rear units. Let me know what you find out.
