Hello friends!
I've got a Coupe -99 20VT with an annoying problem. When driving for a while in fifth gear I get big problems getting the gear out to neutral for downshifting, and then it's hard to find any gear. In normal driving in town I have no issues with changing gear it's only after driving at higher speed in fifth gear. Does anybody have some similar experience or have any ideas what to do?
Best regards
Jonas
Sweden
Stuck in gear
Re: Stuck in gear
Hi Jonas,
I suffered from this problem with my 1998 20vt coupe too. Again it was after long journeys: difficult to come out of 5th gear and eventually not being able to select reverse when parking - but all fine when it cooled down.
I was told that it could be the selector wires from the gear stick expanding - sugestion was to replace these! Then I spoke to a friend of mine who is also a Porsche specialist (and now a Kappa Coupe lover and specialist!) who proposed a gearbox oil change to an ELF product. Rusults: not had the problem since it was done about 2 years ago - and yes I still drive the Kappa as it should be driven!
ELF is now part of the Total group: Total SYN FE 75W-90 (I am double checking and will confirm)
Kind regards,
Gus
UK
Kind regards,
Gus
UK
Re: Stuck in gear
Hi Gus!
Thank you for your input to my problem, I think then that I'm on the right track. I have done the second oil change now and this time to an oil from Redline used for gearboxes in racecars, it seems it works better, but I haven't been on a real long fast motorway trip yet. If there's still problems I'll try the oil you're using.
BR
Jonas
BR
Jonas
