Thema Series II - electronic dampers
Deon
Unread post by Deon »
I have found a set of Eibach springs from an Alfa 164 which is identical to the Themas.
How do I go about disconnecting the existing electronic dampers in order to remove them and try these Eiback springs out?
Deon
agus
Re: Thema Series II - electronic dampers
Unread post by agus »
hi Deon ,
there is nothing special you should do. just remove them, cut the wires and install new dampers,
you can also unplug the main fuses of the electronic suspension at trunk, thats what I did
regards
smokeme
Unread post by smokeme »
There's a connector on each electronic damper to disconnect it, remove fuses to disable the red fault light on the dash..
Return to “51 Thema”
